Access your speed dial contacts
You can access your speed dial contacts list to view, search for, and add new speed dial contacts. Speed dial contacts have a speed dial assigned to them, whereas non-speed dial contacts do not have a speed dial assigned.
- Sign in to User Hub.
- Click Settings > Calling > Contacts.
- You have the option to choose between Speed dial contacts and Non-speed dial contacts.
Add a speed dial contact to your database
- From the contacts window, click Add contact.
- Enter the name and phone number of the contact you would like to add.
- If you would like this contact as a speed dial, use the drop-down menu and select the speed dialing spot.
- Click Add when complete.
